- Joined
- Jul 6, 2014
- Messages
- 312
- Reaction score
- 195
I recently bought an untested Operation Wolf board on here for one of my upcoming projects, upon receiving it and buying an Taito Classic jamma adapter I finally got around to testing it and found that it had no CPU activity whatsoever, fortunately it was just the result of a small break in the trace coming from the PAL chip near the CPU...
After patching it with some enameled wire it was back to life...
Now I wanted to test and see if either of the 2 light sensor boards I had would work but I've could get neither to register any hits on screen. Though it probably is mostly due to testing them out of the gun which I dont have access to test at the moment so I will have to try them again later. BUT. in the meantime I wanted to make sure everything was alright with the boardset so I decided to do some researching online to figure out how to adapt a NES Zapper to work as I had one I had robbed the cord from years ago just laying around, but I was only able to find similar posts about using sega light guns and happ light guns. After some trial and error I was able to achieve some moderate success.
My gun and monitor setup was not 100% accurate as most shots seem to land to the left of were you are aiming at but it worked for testing purposes.
I figured since I couldn't find any guides online for using a zapper with an OP Wolf I'd at least archive what I did here in case someone else need to do this for some odd reason.
First of all is some NES Zapper conversion post online (like for use on a VS Unisystem for example) tell you to remove this transistor in the zapper and bridge 2 of the pads to make them compatible...
YOU DO NOT NEED TO DO SO IN THIS CASE.
I tried it both ways and could not get it to register without it.
So with that in mind here are the steps I took.
The white wire in the Zapper is +5v I just soldered a red wire (red to make it more obvious) to the back of one of the +5v pins on connection H.
The blue wire is for the sensor, so I ran a wire to the leg of inductor L13 on the sound board (which is the first component on pin 5 on connector T)
The brown wire is ground, I soldered it to a small pad on the ground plane near pin 1 on connector T (though you can put it somewhere more convenient for you situation if you need to, I only put it here to get it in the same picture with the sensor wire)
The purple wire is for the trigger and it goes to pin 21 on connector T. If you are using a jamma adapter it will be pin 22 (button 1 for player one)
I didn't bother testing the rockets but if you need to do so just wire up a button using pin 4 on connector M and a ground.
I don't know if this post is useful or not, but I wanted to at least have what I did written down somewhere permanent for future reference.
