SaminVA
Hi, I am looking for some help with a gun problem.
I have a Terminator Salvation with weak gun recoil feedback. I took the gun apart and the problem appears to be between the solenoid coil and the brass knocker. Their is a small shaft threaded on both ends. One end goes inside the coil and the other end goes inside the brass knocker but nether end is attached. Theirs nothing on the brass knocker for the rod to screw into and it's all just floating loose. Looking at the parts diagram in the manual it appears the threaded rod comes with the solenoid coil assembly and the brass knocker is shown next but I don't see how it attaches to the shaft unless theirs something missing in the end of the brass knocker. This is my first time inside one of these guns but it looks like the shaft has broke off at the coil plunger and their's something missing from the brass knocker for the shaft to screw into but that's just a guess. I have a short video that shows it's current condition. I was hoping someone who has already had this problem could look at the video and tell me if I am correct and if all I need is a new coil and knocker to fix the problem. If all else fails I suppose I could take a look inside the other working gun but I was really hoping someone who has already been inside one of these guns could point me in the right direction.
Thanks,
Sam
Thanks,
Sam
