I have a quick question about the wiring on Terminator 2 (gun game) by Midway.
I'm just hoping someone can confirm where the steel braided grounding strap, that runs from the middle of the bottom panel of the cab (next to the ISO Transformer) up toward the front, connects? The end has a ring terminal. I'm just uncertain on where it goes.
There is a stud at the bottom of each gun where another grounding strap goes (this one is on the bottom of the control panel). This same stud is also for the ground wire for each gun.
But where does this separate grounding strap connect? One of the same studs?
