dviper
I'm having a problem with the upper set of lights on the display, the lights all work when I swap out the lower lights to the upper lights on J120. when I take a reading on pin 9 of J120 for the uppper lights I get 7.30 volts but pin 1 I only read 0.03 volts. The book reads that the wire for the upper should be on pin 7 and 1 but I only read .05 to .06 volts on pin 7 and pin 1 reads 0.03 volts. I read 7.68 volts on pin 8 for the lower lights and 1.32 volts on pin 2. When I got the game from my brother the brown wire was on pin 1 and the white with brown trace was on pin 8. The following voltages I took from each pin as follows.
pin #1-0.03 volts
pin #2-1.32 volts
pin #3-0.17 volts
pin #4-key
pin #5-0.18 to 0.24 volts this reading jumps around between these two numbers.
pin #6-1.35 volts
pin #7-0.05 to 0.06 volts this reading jumps back and forth between the two numbers.
pin #8-7.68 volts
pin #9-7.30 volts
pin #10-0.25 to 0.33 volts this reading jumps around between these two numbers.
pin #11-7.31 volts
It seems that pin 1 isnt getting the right voltage or ground. Is the next check from pins J115 to pins on J120 to make sure board isnt bad or fuses and triacs?
HELP!!!!!
Dennis
pin #1-0.03 volts
pin #2-1.32 volts
pin #3-0.17 volts
pin #4-key
pin #6-1.35 volts
pin #8-7.68 volts
pin #9-7.30 volts
pin #11-7.31 volts
HELP!!!!!
Dennis
