Hey guys, picked up a T2 cab over the weekend, trying to get it off of free play, followed the manual completely, but its still on free play. Any tips or tricks to this particular game?
Hmm...possibly, but when I go into the menu, it says free play has been turned off, and I've manually done it on the board as well, and when I restart the game, sure enough, free play is still on the screen..
I'll go home and check the setting on my machine but you won't get a response from me until monday when I come back to work. Maybe somebody else can get you an answer faster.
Try to get a high score and see if it's still there after you turn the machine off. That will let you know if the battery is dead. But since you got the machine, it's good to change it anyway.
What does the Dip Switch Test in the diagnostics test show you ?
(as to what the dip switches are set to)
If you suspect a dead battery for any reason change the Coinage dip switch from CMOS to Dip Switch.
