Terminator 2 Board
killboy2007
Temple, Georgia
Looking for someone on here that I can send board to be repaired Mainboard I live in Georgia if anyone out there that can fix it let me know thanks
Has No Crosshair to calibrate gun issue...
LET me know if you get yours fixed, my t2 has only one of the two crosshairs. I was told that the gun control is all done by the smaller board towards the front of the cabinet. it has some fuses on it (would be worth checking). You might also dbl check all the connections on it as well. Also to make sure the pots are working on the guns you might try going into the calibration menu and look at the x/y axis as you move the guns. If you see movement then the pots are fine. Good luck
yea i checked fuses they look good not broken but i can't seem to get the screws off guns yet the ones with locknuts they are sorta rusty and need a small sockect hex 9mm to get off but i am not giving up on machine yet.....when i take wire off board leading to gun driver x & y goes erratic i check pot voltage 5 and varies when i move forward to back & side to side.....just wondering is there anything in the guns that would stop it from showing up crosshairs to calibrate the game....???
