Tempest Wiring Harness
Madaracs
Golden Valley, Minnesota
Has anyone ever reproduced a wiring harness for an upright Tempest?
I could be completely wrong, but I thought I saw it somewhere here in the forums but I can't seem to find it now.
I need to rebuild my connectors on my harness and I was of course looking for a shortcut.
Else, if anyone has a list of the required connectors and pin sizes to order from Bob I'd appreciate the help.
-A
You should only need to replace the crimp split pins at the main edge connector. Wouldn't hurt to replace the pins at any power/ground wires. Any particular problems you're having? Harness hacked?
Intermittent issues such as:
  • Insert coin doesn't trigger player 1 and 2 lamps.
  • Random blinking pattern on player 1 and 2 lamps after insertion of coin.
  • Game booted up in German or French
  • Random resets
All of the above seemed to only manifest if the game was moved and could be fixed by wiggling and/or re-seating edge connectors.
Isn't there an interconnect cable on the Tempest board too?
  • Random resets
I had issues with mine.. it would turn on, work fine for about a minute, then start resetting. I swore I had already addressed the interconnect, but...that's what it was. Since I thought I'd already done it, I kept thinking it couldn't be that, but it was never done - cracked solder joints, etc..
