Tempest WG6100 Monitor Issue
rockinganker
Chatham, Ontario
To be honest, I'm not sure if this is a monitor issue or pcb issue.
I have a Tempest upright and the monitor curves both the top and bottom of the picture. I replaced all the pcb pots with a set from Bob R and the issue is still present.
The monitor was completely rebuilt including the LV2000 installed, this was done before I bought the machine.
So, is this a board issue or monitor issue?
Here are some pics showing my issue.
Thanks,
Terry
PS.
I know my brightness is up a little high, I have already adjusted it.
Hi
Sounds like the incorrect screen to match the chassis
Do you mind having a look at the number on the tube please
Needs to be 100 degree tube, but is probably 90 degree deflection angle
The 90 degree tube need the amplifone chassis and the 100 degree tube needs the WG6100 setup
links below in my sig if needed
