retroshaun
- Joined
- Jan 26, 2009
- Messages
- 287
- Reaction score
- 1
After many months, the Tempest is alive again!
However - its not without its faults that I wanna run past the more knowledgeable members of the group before messing too much.
So, the tube is currently only displaying red and blue, and the colors seem "offset" a little. Pics should demonstrate. So I am missing green, and of course the mixed colors (white, purple, cyan etc). Thats the main problem. I was told maybe I need to dial in the neckboard potentiometers - would this be the likely cause? If so - which adjustments control which colors? And how do I adjust these? Do I need a specific tool to avoid wobbling the board?
Finally, I noticed the vectors don't seem to join well at the ends (when you complete a level the web lines are way off as is zooms towards you). They also bend/warp at the base of the screen as then go off the edges.
So - I am getting there - can anyone point me in the right direction to get over the final hurdle?
Thanks!
Thanks!
