Phetishboy
I think the difference between Tempest and Centipede cabaret cabinets is the roof. The Tempest cabaret had an air ventilation system in the roof that the centipede cabarets do not have. I believe the plans are online for the Tempest cabaret so you could at least make the correct roof piece to replace the one in a Centipede cabinet (if you're worried about airflow for the 6100. It's only glue, staples and blocking that holds it on so it's easy enough to remove and replace.Looks like I'm committed to building one of these quantum cabarets as well. I just bought a blank pcb and a ton of components. I have a spare 6100 and power brick but am still on the lookout for a cabinet. Might use a centipede since they are cheaper and more common than Tempest.
