Tempest test switch tip.
vintagegamer
Donor 2024
Bear, Delaware
Hope this helps someone out there- my Tempest has no slam switch for some reason, which you need to cycle through the self test. But on the main board up by the led, there is a ring that reads 'slam'. If you jump that to a ground ring on the same board, it works the same way the slam switch would. Hope this helps another amateur out there!
