OU Flight
Trying to get my Tempest going. Here is the problem, game is not playing. Checked the voltages on the power brick and those checked ok. Voyages check good on ARII board. At PCB get the red LED lit that is next to the +5 test lug at top rear of board. For +5 I'm only reading 2.0. The +15 reads +15.
When I check the power for the +5 traced back to the socket on the ARII board it is only 2.0 there. If I unplug the wires from the ARII board the socket then reads +5. So it is obviously not holding the load. I tried a different PCB with the same results. Where to go from here?
