andrewb
Make sure you are grounding the watchdog when you do the VG tests.
It was grounded I believe... I'll have to double check. There were a lot of probes and jumpers all over the place. I remember reading the tool tip and grounding it though.Make sure you are grounding the watchdog when you do the VG tests.
Yeah the VG is definitely broken. I went and repeated the test. WDDIS was definitely grounded. I piggybacked the halt latch LS74 which didn't have any change, so I imagine it's proably something in the decoder, given that it's not watchdogging normally, so the reset counter should be okay?With the watchdog grounded, and running the HALT Test with the "Reset after test" button not lit.. If you are getting a timeout, then your VG is broken. No HALT can be a lot of things. It is part of the VG loop.. It can be anywhere, but I start looking around the state PROM.
At least you have a SUSPECT for goodness sake! Now you can replace it and MAYBE you hit the SUSPECT Jackpot!I've absolved address decoder of any sins through lots of logic probing.
Through a hunch, I pulled the LS175 at J7, because it didn't seem like it was producing any output when running the extended CAT Box tests, and lo and behold, when I stuck it in my chip tester, it failed. That's the 'good news'
The bad news is after excitedly socketing it, thinking my salvation was at hand, I realized I don't have any LS175s in stock.
Sob.
I'd suspect there's a trace shorted somewhere, did the previous work put any jumpers on the bottom from pulling up traces?While I'm waiting for Digikey to make a delivery, I decided to start tooling on the monitor. Like the PCB, it's deffo dead.
I started with AndrewB's pullup guide for 6100s.
Right of the bat, two dead frame transistors. Neat.
So I recapped the whole thing and built a LV2K (thanks Charles Kline). Voltages on the deflection board seem fine for the LV2K. Everything seems okay over there.
However... The HV supply is FUCKED. It's clear that someone tried messing with it in the past. There were caps of the wrong values, and odd transistors installed. I removed most of them and put the right spec in... Nada.
No HV whatsoever. When I looked at the LV inputs, it seems +24 was coming in at -5V (???) and -24 was coming in at -19V (??) Disconnected that plug, everything is right as rain again at the deflection board side. What the hell, man?
Something must be bad somewhere... But what? Not the Zeners. Replaced those as suspect.
