Hi all, I have a factory converted Tempest to Major Havoc cab. The cab actually has Scott451's Tempest/Omega Race/Major Havoc PCB inside so you can play all three games. As anyone who has played these knows Scott did an amazing job.
The monitor plywood allows the display to be mounted in either vertical or horizontal (currently in vertical). Havoc plays surprisingly well in vertical, but as stated you can rotate the monitor and throw a dipswitch on the PCB to put it in horizontal.
Left side art is original Tempest and is in great shape, the right side is the factory converted Havoc overlay. The Tempest art is still underneath but I did not remove it so that the next owner can decide what they want to do. Cab has the following done:
Monitor (K6100):
- All new T0-3 (bottle cap) transistors
- LV2000 installed
- All new caps
- Fuses
- solder reflowed on connector heads
- Tube and frame were cleaned
AR2:
- 2N3055 replaced (was 1981) to ensure your game board doesn't get fried.
Spinner:
- rebuild kit with brass bushings, its buttery smooth now.
Control panel:
- painted new carriage bolts
Here are video and pictures of exterior and interior and video to hopefully cover all the bases, cab is very clean inside and out:
Asking $1,850.
Monitor (K6100):
- LV2000 installed
- All new caps
- Fuses
AR2:
Spinner:
Control panel:
Asking $1,850.
