eXidy
Well, I have a tempest that *was* at some point super nice, but dropped
Jon
The crack is def a problem. If the rest of the cabinet is nice, there has to be a way to save it. I don't know how you'd get a permanent bond on the particle board seam, but maybe:
peel the artwork off that side
use glue in that crack
use ratchet straps around the perimeter or long pipe clamps
bondo, sand, smooth
repro artwork on that one side.
This, and reinforce the crack inside by screwing in a piece of plywood and gluing it. You do that and bond work on the outside, and it won't go anywhere.
