jkoolpe
Bummer to have to resurrect this thread, but this same Tempest went down again...I swear the game is jinxed!
Anyway, it's not getting the +5V again.
But I think I figured it out...again brought the gameboard, A/R board, and power brick to put them all in my working Tempest. Got the same symptom...then tried my working A/R board and still no +5V. And for both A/R boards, the +10.3V was missing. Then put back my working power brick, and sure enough the game came right up, no problem.
So that means it must be the power brick, and I'm pretty sure it's the bridge rectifier that's gone south now. I did some testing/comparisons between the BR in my power brick versus his brick (diode testing with my DVM), and the latter definitely gave some different/off readings (assuming I'm testing it properly).
I have a replacement BR at the ready...just want to make sure I install it correctly since the tab orientation is a little different from the original and the only marking on the new BR is for the positive tab.
I assume I hook up the wire currently attached to the tab marked "+" to the same "+" tab on the replacement, and then remove the original wires and re-attach them to the remaining tabs, one-by-one, in a clockwise fashion to the new BR?
As I understand it, the "+" tab should be directly opposite to the "-" tab?
Again, just want to make sure...
Jon
Jon
