Tekken 3 Converted Cab - help on what manual means...
Snarly
New Jersey
This is from the conversion manual:
This kit can be installed in any industry standard 25 or 27 inch rgb color monitor, or with the appropriate rgb conversion, can be used in conjunction with ntsc compatible video monitors.
Huh???
It means that it will work with any regular arcade CRT monitor (size isn't important), but that it can work with a TV or LCD if you use a video adapter...
perhaps this explains why in the monitor test that there's an Interlace/Non-Interlace setting. I always wondered why that was. lol
