Tekken 2 & TTT wiring. Same?
F_Zero45
College Station, Texas
I know Tekken 2 is using sys11 hardware and Tekken Tag Tournament is using system 12 but looking at both boards the harnesses look the same. Are they both wired the same. I mean could I use my Tekken 2 harnesses on a Tekken Tag Tournament board and not have to mess with any switch or monitor wiring?
I not sure about the harness itself (though I do know TTT has 5 buttons, T2 has 4). I can tell you you wont be able to use both in the same cab, since TTT uses a med. res. monitor and T2 is standard res., just in case you didnt already know.
I didnt know that but luckily I have a Med Res collecting dust in my closet. Besides 2 Punch and 2 Kick buttons what is the 5th button for?
Tekken Tag Tournament is standard res (same hardware as Tekken 3, and I would know, I own both). Tekken 4 is medium res.
the kick harnesses are the same. the Punch attacks and Tag button use JAMMA wiring. the set of wires on the kick harness that appear to be for a button are NOT for a button, they are for the Right Channel Audio for stereo sound (a yellow and an orange wire, if I recall). the Left Channel Audio then outputs through the JAMMA sound wiring. this is selectable in the test mode, much like Konami boards and other Namco games.
