TDL
I'm a little confused on a problem I'm having with this Wurlitzer Las Vegas CD jukebox. It is the same setup as the New York, New York - just a different color and door glass.
After making a selection the carousel continuously rotates.
The LEDs on the SC&C show as:
"Z" always on.
"K" flashes only when the first CD passes under the pickup arm.
"M" not lit.
In the trouble shooting section of the manual (page 50 for Jukebox CDM 4 I, Sympton 6.02) it says the possible fault is . . . "Gray line from M3 to pole 4 of plug BLUE shorted to ground. SCC unit defective (rel. 4 sticks, T4 def.).
SC&C is set for free play, the number of discs on the carousel have been programmed also.
I've changed out the SC&C, CDM 4 I (0040264) with a know working one. Still have this problem.
I've installed a new lamp in the latch bulb socket.
QUESTIONS:
What is "M3" as referenced in the troubleshooting manual?
What does "rel. 4 sticks" refer to?
Does "T4 def." refer to a fuse?
Thanks for any help you can offer.
Tom
"Z" always on.
"M" not lit.
QUESTIONS:
Tom
