modessitt
Ever have a hard time taking board-stacks apart because of those standoffs?
There is a specific tool for removing them that looks like a plastic tube with a slightly smaller diameter than a Bic pen (which is too big). You just push it down on the standoff and lift the PCB off. Sometimes you'll find them inside a cab or in a manual bag.
A lot of people don't have this tool, and either pinch it together with a pair of needle-nose pliers, their fingers, or just pull hard until it pops off (and sometimes breaks the standoff).
Well, if you don't have the proper tool, you can use a normal sodapult (see below) just as well.
The tip is the right diameter. Just push it over the top of the standoff, and the PCB will lift right off.
