Tech/Picture request: Midway Haunted House
thepita007
Jacksonville, Florida
I need some photos of the coin door wiring for a midway haunted house rifle games.
Mine is having a strange issue, when the coin door harness is plugged in a fuse a 6 amp immediately blows. I have traced the issue down to the tilt/slam switch.
Anyone ever have this issue before? Went thru the schematics and checked everything cant seem to find the issue.
the fuse that blows if the coin door is installed is the 50v fuse.
there are no lock out coils in the circuit. Fuse doesn't blow if coin door is not connected.
I have re-wired and verified coin door wiring.
Update: this is a better explanation of the issue
When the tilt/slam switch is closed the 50v fuse blows. I have checked the wiring and relays and everything appears normal.
I have removed the coin door and jumpered the connection for the tilt/slam switch and the fuse still blows so its not the coin door wiring.
Anyone have any ideas this one has me stumped.
did the game ever work? with the door unplugged, can you trip the coin relay or start relay and play a game?
yes with the coin door unplugged I can coin up using the 25 cent relay and start using the start relay everything works.
Issue only arises when the slam/tilt switch is plugged in. The coin door wont function if its unplugged.
