monster kong
culprit-
ofrroad thunder with neotec 2701 monitor
problem- after game is on for a few minutes, monitor gets very bright with retrace lines and the picture is unseen because its full bright..
what i did: recapped monitor and reflowed pins.
NOW- monitor still does the same thing with brightness.
*note: if i tap cabinet top a few times, monitor will go back to normal and brightness problem goes away. but, 5 minutes later, its all bright with retrace lines again.
i swapped remotes from another working neotec and it still does the same thing.
cabinet connections (AC and color signals) to monitor are fine.
