ceckitti
Finally got game set up. Picked it up in trade about 6 months ago. Other party told me it had some problems....understatement of the year.
Drop Target coil was melted down BIG time, Coil wires were cut and spliced together, and the transistor was cut off the driver board.
I replaced the coil (only had a Stern 26-1200, this should be ok right?), replaced the transistor (called for 102..only had 122), wired coil back up and now the Drop Target coil stays engaged on power up.
I tried installing my spare driver board with the correct Tip102 and it still did the same thing.
Could the problem be the coil?
Could someone snap a quick pic of their Drop Target coil and assembly so I can tell if i have everything wired up correctly?
Thanks in advance.
Tom
Thanks in advance.
Tom
