Tech: Asteroids sound problems
Tenn_pin
La Vergne, Tennessee
Fixed: Asteroids sound problems
My Asteroids has developed a problem with sounds. The explosion sound is good until the thrust is used. When the thrust is pushed, the thrust sound does not happen, just a quick hum. Then the explosion sound is the same quick hum as the thrust. I am not that great at reading the schematics and cannot understand which chip is connected to both sounds. Can someone tell me which chip is the problem?
Thanks,
Randel
Fixed
I was ready to replace chip R11 when I noticed the legs of C63 and R75 were touching. After referring to a parts board and the schematics, I thought they should be separate. Using a pick, I separated the legs (and clipped them shorter) and everything works fine now.
Thanks for the help.
Randel
Randel
Is it not a great feeling when you fix your own stuff with the help of KLOV members.
