You are using an out of date browser. It may not display this or other websites correctly. You should upgrade or use an alternative browser.
Museum of the Game® & International Arcade Museum® Forums
Is it possible to change a mini golf cart into team hat trick? If so what am I missing.
I get it to go to a "please wait a moment" screen then it displays garbage and reboots.
Possible dumb things I could be doing.
This isn't possible.
This cannot be tested on an upright setup
There is some security feature i dont know about.
The pal chips are different
Im using 27256 rather than 128 and need to do something to make that work (other than doubling the program). It seems the a14 (or P_) pin comes from the cpu so I just left it as is (maybe I should make sure its not floating).
