TDA2030 (or LM1875 or TDA2050)
mrbill08
Donor 5 years: 2014-2015, 2019, 2022-2023
Illinois
Hello,
I'm looking for a TDA2030 audio amplifier.
An LM1875 or TDA2050 will also work. Used is OK.
I can buy or trade some other part in exchange.
It's the only part I need right now and if I order from any sources I'll get soaked for shipping charges or a long wait and have to buy more parts I don't really need right now to make it worth the shipping cost.
Thanks and Happy New Year!!
Bill
I just took a look and the closest thing I have is a TDA2003 which is the same except its 10W instead of 14W(TDA2030). The LM part is 20W.
If you wanted to give it a shot I can send you one or two. Worse case is it will burn up if you crank the volume.
Did you check channelmanics site? He might have something?
Actually, I have a couple totes of junk boards that I can check. Might be able to pull a used one.
Please send the part, Mike. I have Mark as a backup in case any of the others are fried when I test the boards. There are six on the two amplifier boards that I need to test with one already bad due to rough handling of the heatsink which snapped off the leads Two others had broken leads that I was able to repair. I am wiring up the power supply harnesses to the special power supply now along with making the last three cables to complete the test setup. I can test everything without that amplifier in the meantime.
Thanks,
Bill
I have one for him but it wouldnt go out until Monday so that will put it there on wensday or thursday.
