I am now focusing on cleaning up my Tank cocktail instead of the trivia whiz.
So far...
1)I am in the process of getting a light bulb for the coin door.
*2)In the process of fix in the button on one of the joysticks (It sometimes stays down)DONE!
3)going to get a new plastic top on the table
4)Clean the cabinet
5)Fix/paint the coin door and get a new coin mech.
http://forums.arcade-museum.com/showthread.php?t=243462
^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^images above
I have figured out that the joystick problem is a missing bolt/washer (or I think that is the problem). The good joystick has one more bolt so that when you push the button down it stopped is from going down to far I also cleaned the area where the joysticks are housed.
images are here
(PIC-1 image of the bad joystick)(PIC-2 dirty housing of joysticks)(PIC-3 a image of the other joystick)(PIC-4 a image of the good joystick...in the upper right corner of the picture you see a black disc next that a bolt and next to that a washer...the other joystick is missing the washer.)PIC-5
Thanks!
G12
So far...
4)Clean the cabinet
images are here
Thanks!
G12
