I am having some issues with my TFTC pin I was hoping someone might have some insight into.
First, sometimes when you lose a ball it doesn't always recognize that you did. The trough switches and diodes are all new. I replaced several Molex connectors as well. It really seemed like it was the connectors at first but has started doing this again. There seems to be something loose on the left side of the machine. If you keep tapping the left flipper button after losing the ball it will finally end the round. Anyone have any ideas what else could be causing this? Like I said, seems like a wire, a connector, something, is loose.
Second, on the right ramp "Double Jackpot", you are to light up four items "Play The Organ", "Living Dead", "Chainsaw Mode", and "Grave Digger". But after losing a ball, it resets to the first one, "Living Dead", instead of keeping the progress you made in lighting them up. No idea why it does this. Just started doing it recently.
Any help/ideas would be appreciated.
Thanks.
Thanks.
