Taito Power Supply schematic needed....
modessitt
Austin, Texas
Trying to fix a Taito Trimline Space Invaders cabaret. +5 is fluctuating between +9 and +11. I get a steady buzz under load, and a recurring buzz when disconnected from the board.
Can't find a schematic for the PS anywhere. I've seen it was mentioned in various Taito manuals from 79-80 games, but none have the PS schematic.
If anyone can point me at one, I'd appreciate it.
This is the PS I am talking about:
I have a hard copy of all the SI trimline schematics. I can probably scan it for you tomorrow.
EDIT; I tried taking a high res pic, but it was too fuzzy to read.
Lemme know. I looked through the Trimline schematics online, and they had every board EXCEPT the power supply...
Taito power supply
That is the same power supply used in my cocktail Stratovox game... try some of the cocktail game manuals. Unfortunately, I do not have the power supply schematic in my manual either. Please let me know if you find it!
Kenneth
here you go.
I don't know how to stitch together two scans, so I just scanned the schematic that was in the center of a mostly blank double page. all the good info is there, just without the border around the drawing and the little box that doesn't have any useful info.
edit; "Your file of 168.0 KB bytes exceeds the forum's limit of 19.5 KB for this filetype." damn.
edit2; emailed to ya.
Thanks ESTF. I guess you sent it to my JR email? I'll check when I get home.
Kenneth
Yeah, I checked a bunch of Taito manuals (including Stratovox) before posting here. Unfortunately, all just give a casual mention of it, or show where the adjustments are, but don't include a schematic.
I'll check this one ESTF sent, and post it if it turns out to be the right one....
The Taito Trimline Space Invaders manual does show a pinout of the power supply.
It puts out +5, -5, +12, -12, Gnd, and has a reset signal to the cpu board.
I can send it again to a different addresss if you need it sooner.
where are all the other trimline schematics posted? I'll check and see if there are any others I have that aren't online.
The Trimline manual is available on Xmission and a few other places. Brentradio has a bunch of Taito SI stuff, too, including Trimline docs. But none had the PS schematic....
Yeah, I saw that, which is how I figured out my +12 was so high and was pulsing between +10.6 and +12.2
If it wasn't for that Reset signal, I'd probably just pop a new PS in it...
Is anything getting hot? Maybe the voltage regulator is crapping out?
Nothing's getting hot that isn't already attached to a heat sink. I thought about the VR, but there may be several. All of them are reading fine under diode test, but I need to track the schematic to see what voltages I should be expecting where....
Here is the schematic sent to me from ESTF. Thanks, Ben...
UPDATE:
I did some tracing and found some issues with the C945 transistor at Q8. Replaced it, and my +5 is no longer fluctuating between 10.6 and 12.3. It is now holding steady at +7.12. I figured it might be doing that because there was no load attached, so I stuck it back in the cab, and found it to still be +7.12. Adjusting the +5 pot does nothing (pot is ok).
Now, if you check that schematic above, I have verified the voltage is high BEFORE the fuse at F5, since removing does nothing. I also checked across the outer windings of the output of T3, and supposedly have +5.0 (although I'm not sure I'm reading it in the right way).
Am I going to need to replace all those 2200uF caps between T3 and the fuse?
If the electrolytic caps go open or down in value, the DC output voltage would go down while AC ripple would go up.
Check/replace IC2 and D24.
Good point. Yeah, I was thinking about IC2, but it'll have to wait until tomorrow now...
just an FYI, mine was doing the same thing, had enough projects to do so I bought one from tntamusements. I did have to replace a zener on the tnt amusement one but in retrospect that may have been my fault.
Okay, I don't want to spend too much time on this, and since it's going into a commercial location, I think a newer PS would be a better bet for long-term stability.
I'm worried about the RESET signal coming from the PS. Looking at the schematic, it appears to be generated by IC3 as a result of the +5 signal being detected at the proper levels. With that the case, could I make trace cuts where I've marked the green lines in the schematic below, then attach the +5 at the red dot and GND at the black dot - and make it work as intended? All my other voltages are present as indicated.
