Taito power supply question
Rampart35
Donor 2019
Renton, Washington
I have a Taito power supply (AAM 60009) from a space invader( I think) and wanted to hook it up to a 120 AC line, I noticed that it was originally from a Japanese cabinet that supplied only 100 VAC. Can I hook it up without any issues or do I need to convert the voltage?
is that the same one Lunar Rescue used? I might pull that later, cause I need the cap values again. for its age it still works perfectly.
Yes, I believe it is. Was your LR complete? If so, there should be an isolation transformer that feeds the power supply. I wanted to know what the iso was rated for, maybe 5A ??? I have one that is only rated for 2A and I am nervous about melting the transformer....
