Taito Multi-board- how do I adjust the volume?
Wiz
Ann Arbor, Michigan
Hey peeps, I picked up a Multi-Taito a couple weeks back and got it hooked up and reset button going. The problem I have is that the volume is extremely low and if I have any other games going or any other sound for that matter you cannot hear it. I cannot find a volume pot or adjustments (dips or anything adjustable) of any kind on the board. Does anyone know if I can turn up the volume on this board, and if so, how? Thanks a lot!
I believe you need to hook up your TEST and SERVICE switches... from recollection those two switches increase and decrease volume. There is a pinout chart around somewhere...
Use the P2 stick up/down on the menu screen.
THAT is right... I remember now... my EA only has one stick, I wired up a couple buttons to the P2 stick up and down and stuck them in the coin door area to increase/decrease volume...
Sorry for the confusion... it's been a few months since I last worked on that machine.
YESSSSSSSSSSSSSSSS! and yes, I did yell that. You guys are the shiz! Thanks for the tips, just turned up the volume and put up 158K on Zoo Keeper. I need to work on my skills, but man, music does help. Thanks again!
