Taito Marquee Lights on Qbert Harness & PS
dsteinmann
Wentzville, Missouri
Does this light take 4.8v and do i need to use both connectors on the back?
and if its only 4.8 do you think i can wire it into the Coin Mech Lights or do you think that would put a strain on the power supply?
What game is that? What is the bulb number that is in there? If they are 44's or 47's, they are 5v. You probably only need to connect one side of that marquee harness....that way it looks like its wired.
Im not sure if it was a elevator action or jungle hunt cabinet. BUt if they are 5v bulbs do you think it would mess the power supply up trying to power all those bulbs?
Are you trying to stick a Taito marquee fixture in a Qbert cabinet? The Taito marquee fixture was originally powered by a 6 volt winding off a transformer...the voltage went into one of those connectors on the end......then the voltage went out the other connector and went off to the bezel instruction area and powered a couple more lights.
Edward
