What are the white wires for?Are they a ground?These white wires are cut and spliced R16 looks correct as far as the other colors.Do I need these wires?I was told this harness is for a EA.
Jeff
Ok looking at the manual the white wires that are spliced are for the right coin lock and reset.Why would a op slice these together?Why would the other one just be cut?Would you attach these or leave them as the are?
I bought a EA project that had no wiring.I bought this harness he that said It was from a box that said EA harness on It.I have not plugged it in yet I want to figure out the splice first before I plug it In.I was just wondering If anyone knows what the splice is for and If It Is needed In a EA?
