scamp
Taito 19" Horizontal Rastor Position Adj Jumper
I recently picked up a Jungle King I'm working on and the picture seems to be slightly shifted to the left. Upon reviewing the monitor manual it seems there is a jumper that can be used to shift the picture either left or right...there is a similar one for a vertical rastor position as well...
The jumper seems to be a wire soldered to the chassis and then it has some sort of connector and a sheath on it....I can see this on the vertical side...HOWEVER..it seem the horizontal jumper has been removed. I see a remnant soldered to the board, but the wire is gone...
So my question is, how can I replace this? Why is the jumper soldered to the board itself? (is it grounding it? is it part of a circuit?)
Any info would be appreciated since I'm not really sure how to proceed...Other than that, the monitor seems to work its just a bit too far left...not sure why there wasn't simple a potentiometer on these monitors to move the picture over a bit!!
thanks!!
thanks!!
