Ok, so with P/S out, removed the 2n6055, tested it but it's good, unscrewed the X-former and was able to get the 5v companion board in position to really look it over and interestingly enough I found some corrosion on the board behind 330uf cap. Although there wasn't visual damage from the top, it definitely leaked out the back. Confirmed when tested, has about 1/4 of it's capacity left, it's bad.
View attachment 778755View attachment 778754
Then proceed to check the other small 220uf cap to the left of it and that one tested completely open, shot!
At this point, I carefully removed the corrosion from the pcb with a little vinegar, baking, soda, and a soft toothbrush, was able to clean it up pretty good, I don't believe these caps were ever changed so at this point with some bad and with it out? Decided it was the right thing to do was recap the P/S. I had ordered good quality replacements caps, even the large one's (not cheap) just in case so had everything ready to go. I replaced the 2n6055 with the 2n6059 since had the companion board out, tested the bridge rectifier but all 4 legs were good when I de-soldered it so left that alone. It's like new now:
View attachment 778757 View attachment 778758 View attachment 778759
From here I discharged the monitor, unplugged everything including the neck, fired up just the P/S with nothing connected, tested all voltages coming out of it down to J1 connector to the main PCB, everything is PERFECT, slightly higher than +25, -25, 5v, the 6.3 ac on the supply, everything. Able to adjust the 5v just fine with the potentiometer, stable.
Next, plugged in J1 on the main PCB, turned it back on, Got excited to see NO red light! BUT however, there's no 5v
, as a matter of fact, it's at about .5v now on the board, not 5v, tested it every way, crap! but hold on, because of the new caps now that were blown and most likely holding, maybe just a step forward.
I felt around on the main board, there's no chips hot or even warm. (All I have is the p/s connected to the main pcb) nothing else, no monitor, speakers, soundcard, nothing. It doesn't blow the 2 circuit breakers this way neither.
So let me know your thoughts? Here's what I'm thinking now since it's one of the only things left I didn't check with the P/S. There's a current limit circuit on there as
@toledoflyer had mentioned earlier. It has a MC1723CL. It appears to be a voltage regulator too as I'm looking into it. What does it do? and HOW do I test it? Possible to probe it? If so I'd need specific directions on the correct procedure to do that please. Keep in mind that It's very hard to get in there while the supply is turned on but maybe possible if I'm careful, it's the one chip i haven't felt if it's hot, lol, but don't want to touch in there with my finger. It might be better to just replace it with a new known good chip?
Also, here's the specsheet on that voltage regulator chip and it's suitable replacements. If so, I would socket it and it replace it with best recommendation but would like to here opinions first, any other possible suggestions too. Thanks
