That I will have to look into. I am hoping to start tearing into this tonight. Anyone else ever put a fliptronics 2 board in? I have one plug that isn't plugged in and I am thinking it controls the thing flips thing.
It's probably black wires correct? It doesn't need to be plugged in when using a Fliptronics 2 board. For reference (from Clay's guides)
[FONT=verdana,arial,helv,helvetica][SIZE=-1]Using a Fliptronics_II board in an Addams Family: [/SIZE][/FONT]
- [FONT=verdana,arial,helv,helvetica][SIZE=-1]
- Fliptronics_II J902 = Fliptronics_I J802
- Fliptronics_II J905 = Fliptronics_I J805
- Fliptronics_II J906 = Fliptronics_I J806
- Fliptronics_II J904 = Fliptronics_I J804
- Fliptronics_II J903 = Fliptronics_I J803 (ribbon cable)
- Fliptronics_II connectors not used: J901, J907[/SIZE][/FONT]
[FONT=verdana,arial,helv,helvetica][SIZE=-1]Using a Fliptronics_II board in an Addams Family.
Power Driver board (only pertaining to flipper power section): [/SIZE][/FONT]
- J111 - Remove connector (disconnect) and do no use
- J112 - Leave connector
- J110 - Leave connector
- J109 - Leave connector[/SIZE][/FONT]
Flipper Power Board board (small board, backbox middle right side): [/SIZE][/FONT]
- J901 - Leave connector
- J902 - Leave connector
- J903 - Leave connector[/SIZE][/FONT]
Thing flips is a CPU controlled feature. The flipper coils can be driven by the CPU.
You don't need the entire assembly for the anything unless something is broken. Buy some sleeves, clean it up and those components will work fine.
