T2 Terminator 2 monitor and chassis match identification help (25 VII0 III COTY)
jamierudy
Donor 2023-2024
NORTH MIAMI, Florida
So I got this T2 from auction and to my surprise it was missing its chassis and quite a bit else, I understand these used the K7000. I have no experience rebuilding these. I think it's a wild assumption that this is the original wells gardner monitor in there (see pics) it does have a WG serial sticker on it.. However it uses a (8-pin male plug on its tube) and I can't find the matching chassis for that on any of the neck boards that came with the K7000. (I just want to get the correct chassis and neck board to get this to work) There was one identifier which said "25 VII0 III COTY" embossed on the monitor.. any help would be appreciated. (It may very well be 25K7197 as the label says on the monitor harness. If so what are my options for a suitable chassis and an 8-pin neck board assuming it can only use an 8-pin neck. Thanks!
that's a CR-23 socket. it's 10-pin. the focus counts as a pin and there's the other one that's dummied out.
What was the auction price for this beauty?
Well it was missing the chassis, the knowledge of how to re-wire a new chassis, the guns were a total mess, cracked and both gun motors removed buttons broken, but yeah I mean assuming the K7193 tube works, assuming it is the K7193 which it should be at this point with a CR-23, which is a huge assumption considering they stripped this otherwise, all I have to do is general cabinet restoration, new art work all around, gaskets, spark plugs, new radiator, and as the heaviest cabinet a genuine miracle to get this into my upstairs new apartment.
25K7197 is just a 25" K7000 chassis. I sell refurbished ones if you're interested. Checkout "Mikes's amateur monitor repair" on youtube. He has a ton of K7000 videos, which include how to hook them up.
yes i just bought one i was about to send to paul as it came untested how much for it?
