I was helping my father with his T2 pin lastnight but couldn't figure out what was causing the issue. The drpp target under the Terminator head won't stay up. When you shoot the ball into the area behind the target it is then supposed to shoot back up while the ball goes over to the "gun". The target will pop up but then drops back down. It does this 5 times in a row then just stays down.
I figure it has to be 1 of 2 things. Either the sensor that says that the target was hit (so it will drop) is mis-aligned so it keeps dropping or whatever is supposed to catch the target to keep it up is not catching. I spent about 30 minutes checking it out lastnight but there is so much going on back there that it was damn near impossible to tell what is what on the back of the playfield. I found the solenoid that pops the target back up and the switch that senses when it is down but I couldn't find the switch that senses when it is hit.
Any ideas?
Any ideas?
