T Z optic problem
HAVASUGAMEMAN
lake havasu city, Arizona
i have been trying to get this game going, have done alot to it already but cant seem to find the prob. with some of the optos.traced it down to col. 7 .. took voltages on opto board (under playfeild) all where good take measurment at opto and two are reading at about 9.3v when blocked they drop to 6.5 or so , on working opto read is 11.5 blocked about .7 also getting good read on trans at about 1.3v on all optos ? also last two sw in that colm. middle and upper million work fine not sure if that matters? because there not optos ? thanks for the help
Well I will say if your having issues with col 7. I would check your opto board under the playfield. you may have a failing LM339... I normally socket and replace them all.
