kspiff
Doesn't somebody make 3/4" smooth black molding with a slightly oversized insert part for this type of situation? Coulda sworn somebody did, but I do drive a Caddy so...
HAHA! Nice crossthread post! Rep for you!
Fill the slot with bondo and then re-cut it.
+1, I have had good luck with that method alsoThis is the only "proper" way to fix the issue. A "quick" fix that is easy to reverse and fix properly would be to use strips of duct-tape on the spline ... I did that for Black Widow and it worked fine.
If it is a decent game please don't use Gorilla glue or construction adhesive. If a new owner ever wants to change the molding for a restore or whatever you just made a hell of a mess for them.
