T-Mek joystick issue
Belgium, Wisconsin
OK, so T-Mek has two seats, each with two joysticks. Well the right joystick on the right seat has been acting up. It "reset" itself to where forward doesn't work. I go into the test menu and reset the limits and it will work fine for about 2 rounds/levels and then it's back to the way it was. I've even tried swapping the joystick with the left seat and still get the same problem so I'm pretty sure it's not an issue with the joystick itself. So, does this sounds more like a wiring issue or a board issue?
