T-MEK artwork?
jimbodeanny
Does NOS T-MEK art ever pop up? Just curious.
The T-MEK I recently picked up is actually in pretty good shape art-wise, but one of the side panels on the seat section (left side), has some small sections where the artwork has pealed/cracked off. Not a huge deal, but if somehow I were able to pick up just that piece, that'd be ideal -- but I doubt that opportunity is likely :)
I've never seen it, though I've seen random parts of the cabinet shows up here and there that could used the same way, I suppose. I doubt there were kit versions, so I don't think it's very likely that you'll find an artwork other than repros, and I don't think I've ever seen repro art either.
This isn't the best photo, but I've circled the problem areas. It's mostly the piece on the seat section that I'm concerned with, but I'd be interested in either of those pieces of art.
I can take better photos later in the week if needed.
Thanks!
If NOS art exists, I'd like to reproduce it for the entire machine.
I believe there was someone here a couple of years ago that was talking about doing this as well, but I have no idea whatever happened to it. When I get home, I may try searching for the thread unless someone else happens to remember at least who it was.
I've never seen one that didn't have some artwork missing from seat section. The two areas you pointed out are the most common. The bottom rubs off from the metal plate that joins the front and back. The more the machine was taken apart and moved, the more likely it is to be damaged there. I have no idea why the top of the rear is always torn, but it is.
Hm. Yeah, it's frustrating, but I can live with it for now. :)
