jeff412
I am rebuilding a Haunted House pinball. I was following the reset section alternative on www.pinrepair.com. Clay says that the flat side should face down and that pin 3 should be on the right. Well if the flat side is facing down then pin 3 is on the left. At least according to this http://html.alldatasheet.com/html-pdf/58541/DALLAS/DS1811/180/1/DS1811.html I agree that pin 3 should be on the right, but the flat side should be up. Am I wrong about this? I also have a Game Plan Sharpshooter II that I am repairing. In his Game Plan reset section repair guide he says that you can use an MCP101-450 instead of the Dallas DS1811. The MCP101 is an active high reset device (http://www.datasheetcatalog.org/datasheet/microchip/11187f.pdf) and the DS1811 is an active low device. I believe his information is incorrect about using the mcp101 as well. I think it should be an MCP100-450 instead. Can anyone verify who is correct? Me or him?
