Syncing a 60 in 1 to k4900, I'm stuck
tron guy
Super Moderator
Staff member
Donor 12 years: 2011, 2015-2025
Eureka, California
I feel like I've tried everything.
I don't need a link to bob roberts sync page. I just need confirmation of which pin(s) shoukd have the sync wire connected, then I can determine if I have acdifferent monitor issue.
-H sync: row of 3 pins, pin closest to tube.
Right, which pin(s) need to get the sync wire?
My tpg puts out a perfect image with the 2 separate sync wires on the 2 pins closest to the tube.
In true tron guy fashion I neglect the obvious.
The freakin pcb was set to vga instead of cga.
Problem solved.
