Sync Problem? with Hook by Irem
XianXi
Honolulu, Hawaii
Working on a Hook PCB with a weird problem.
Upon firing it up it boots normally then when it gets to the attract mode it makes it seem like someone is playing with the monitor voltage.
I don't think it's the sync as the picture pincushions like someone flipping the monitor off then it comes back and does it randomly.
Traced the sync back to a resistor pack which tested fine (100ohms per in/out) then from there it goes to the upper board to a custom QFP. I checked the resistors on the QFP and all are the same 250ohm. Roms all check out and are flashing normally.
Does the QFP generate the Sync signal itself?
