Sync issue with JROK card in Defender K4600
YeastLord
Donor 4 years: 2015, 2020, 2023, 2025
Clinton, New Jersey
After a year of screwing with the original Defender boards and not being able to play the game I bought a JROK card and adapter. I wanted to leave the harness intact if I ever want to put the original boards back in.
After hooking everything up I now have a sync issue. Everything seems to be hooked up correctly. I noticed that on the adapter there are two wires coming from the adapter for sync. Do I need to hook these up to something?
Thanks for the help.
Yes, it needs to be connected to the 2-pin sync-header on the board. See page 20 and 21 in the manual.
Here's the diagram
I knew the answer to this. Just sayin' (as I just put the same in my StarGate + adapter harness etc). :D
I was trying to understand why...
but is this a separate header that goes to another plug to put on the negative sync pins?
There are 2 sync outputs on the board (!)
  • Standard JAMMA negative composite video sync from the JAMMA connector.
  • Secondary separate positive horizontal and vertical syncs output on the 2 pin header, which match the original board's H & V sync outputs.
The H & V outputs are on a separate header because the JAMMA standard doesn't have H & V sync ouputs on the connector.
- James
I'd have to see how it's hooked up, unless your board outputs positive sync too? I've only ever used your boards with JAMMA harnesses.
Yes, the 2-pin header is for positive Horiz and Vertical sync output.
- James
Here's the diagram
That was it! It's amazing to finally play Defender.
After a bit of searching the only manual I could find was 9 pages.
Is the full one posted someplace?
Thanks again for all the help!
