Switching Power Supply Shorted, Easy Fix?
arcadeaction
Donor 2013-2014
Gainesville, Florida
Have a switching power supply whose wires from 5V and ground were shorted for about a second and now it doesn't power on. I've isolated the issue to the power supply as all cab fuses are good and the PS doesn't light up when put into another working cab. The fuse inside the power supply is also good.
I'm going through a repair manual, but thought I'd ask in case there is something easiest to check. It's this PS: https://na.suzohapp.com/products/power_supplies/80-0210-00
