modessitt
So I'm trying to get this Galaxian Cocktail I picked up back from the dead.
I got the monitor working now, but am getting absolutely nothing on the screen (other than a glow when I turn the brightness up).
I'm wondering if I should just cut the wires going to the edge connector and attach them to the switcher or not. I know it's usually AC going to the connector, which gets converted to DC on the board. One site says to hook the switcher to the wires and crank the +5 all the way up to +6 or so, and let the board bring it back down.
Since someone pulled the old "aluminum foil around the blown fuse" trick, I'm not even sure the board works. Even if it does, the AC-to-DC section could have blown, and maybe I should attach my +5, +12, and GND straight to the board after that section? What are the best points to attach them if this is the best method?
Currently, I have about +6.79 coming in on 3 & C, and +3.45 on 4 & D, as well as +6.98 coming in on the +12 lines from the transformer.
