monster kong
Switcher install question: i want to put a switcher in my Pac Man Cabaret. im going to use the 60 in 1 board that requires no hacking with the new style jamma adapter in case i want to install the normal pac board in the future again stock. it also uses player 1 and 2 buttons for jump, etc so you dont have to hack a control panel either. anyhow, in full size uprights, you are supposed to tap the ac voltage needed for the switcher at the marquee light. cabaret pac mans have (5) 12 volt (161) bulbs for marquee, not 120v ac bulb like the full size. so, where is a safe spot to tap into AC in a cabaret?
