Switch to turn the picture on a VisionPro?
pacray
Erie, Colorado
Does anyone know if there is a switch to rotate the picture 180 degrees on the chassis of a VisionPro monitor?
yeah, ray, i do... flip yellow and orange for vertical, red and blue for horizontal. no switch though. if you need to rotate it both horizontal and vertical, there's actually a reversed h/v solder point on the chassis next to the regular one, that you just solder the male end of the connector into. the pins are pretty easy to get out of the connector on the yoke wiring, though.
what's it going into? older b/w mirror style midway game? discs of tron?
Flipping the wires is the easiest way.
I have a Tovis,which is the same as Vision Pro 2 and I just split the connector and swapped the wires.
Make sure you don't swap vert. wires with horiz. wires.
Keep them on the same set of pins.
I have swapped yoke wires before, but the ones that need swapping are in Canada, and I am trying to avoid figuring out how to avoid having the chassis shipped back to me to make the swap, or finding someone there who can do it for me.
does a roadblasters have a dip switch for flipping picture? replaced the worn out tired out old g07 with another monitor lol
Like Mod stated, most pcbs have a dip for it. If not, and you don't feel comfortable swapping yoke wires (pretty easy though) you can always rotate the tube in the frame....just a thought.
does it just need to be flipped in a different direction?
the way you stated it, ray, it seems like you want to reverse the image (like on a space invaders)...
well i mounted the new monitor in the correct way into the cabinet with the chassis on the bottom and the picture was upside down lol. i reversed the monitor and placed it inside with the chassis on the top instead of the bottom and the game plays flawless however was just curious
